Skip to content
Manpage for sbank Commands
sbank [options]
DESCRIPTION
HPC Accounting System Command Line Interface
detail meta command
"detail" meta command displays information in a long format with history updates, where appropriate.
list meta command
"list" meta command displays information in a table format, but no history updates are displayed.
IMPORTANT NOTES 1. All dates entered shall be interpreted as UTC 2. non-admin users will only be able to see their content (jobs, charges, etc.) 3. project admin users will be able to see all of the content for their projects 4. staff admin users will be able to see all the content 5. --help and -h are the help options.
META COMMANDS
- detail [options]
- list [options] (DEFAULT)
DETAIL COMMANDS * allocations [-a | -e |-f|-j|-n|-p|-r|-t|-u|-w|-E|-H|-I|-O|-S|-T|...] [ ... ] (DEFAULT) * jobs [-a|-e|-f|-j|-n|-p|-r|-t|-u|-w|-E|-H|-S|-T|...] [ ... ] * projects [-a|-f|-n|-p|-r|-u|-w|-E|-H|-I|-S|...] [ ... ] * transactions [-a|-e|-f|-j|-n|-p|-r|-t|-u|-w|-E|-H|-S|-T|...] [ ... ] * users [-a|-f|-n|-p|-r|-u|-w|-E|-H|-S|...] [ ... ]
LIST COMMANDS * allocations [-a|-c|-e|-f|-j|-n|-p|-r|-t|-u|-w|-E|-H|-I|-O|-S|-T|...] (DEFAULT) * jobs [-a|-e|-f|-j|-n|-p|-r|-t|-u|-w|-E|-H|-S|-T|...] projects [-a|-f|-n|-p|-r|-u|-w|-E|-H|-I|-S|...] * transactions [-a|-c|-e|-f|-j|-n|-p|-r|-t|-u|-w|-E|-H|-S|-T|...] * users [-a|-f|-n|-p|-r|-u|-w|-E|-H|-S|...]
OPTIONS
-a --allocation
enter allocation id
-c --comment
enter comment for new or edit commands, display comment for list commands
-e --event-id
enter event db id; event db id is an internal id created by the charging system
-f --field
enter [:], width is optional; enter -f? or -f "?" for available fields, + to add fields
-h --help
command line help
-j --jobid
enter jobid; jobid is created by the scheduler and is not unique
-n --num-field
enter number of fields to display
-p --project
enter name or id, DO NOT MIX, enter 'all' to get all, wild cards '*' is allowed, but only on names
-r --resource
-s --suballocation
enter suballocation id
-t --transaction
enter transaction id
-u --user
-w --field-width
enter the field width as follows: :, enter -w? or -w "?" for available fields
-E --end
enter end datetime filter
-H --human-readable
abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions) ...
-I --get-inactive
include inactive allocations
-O --get-only-inactive
get only inactive allocations
-S --start
enter start datetime filter
-T --Type
enter type of transaction
--all-charges
for list allocations | projects | users, only show info with charges
--at
enter transaction-created datetime filter
--award-category
enter allocation award category
--award-type-name
enter allocation award-type name
--created
enter created datetime filter
--debug
enter debug level
--get-deleted
get deleted objects
--get-not-charged
get jobs that have not been charged
--get-only-deleted
get only deleted objects
--history-date-range
enter history datetime filter
--home-dir
enter the directory to store the pbs meta file
--ignore-pbs-files
all new pbs files will be ignored and marked as processed
--last-updated
enter last updated datetime filter
--no-commas
remove commas from comma-separated thousands
--no-header
do not display header
--no-history
do not display history information
--no-rows
do not display rows
--no-sys-msg
do not display system message
--no-totals
do not display totals
--queued
enter queued datetime filter
MORE OPTION EXPLANATIONS
For -a, -e, -f, -w, -j, -p, -r, -t, -u, -T, --award-categories, --award_type_names, --cbank_refs options:
These options can be entered multiple times for different values or entered once for multiple values.
Examples:
  1. sbank-list-allocation -u "pershey rojas allcock" or > sbank-list-allocation -u pershey -u rojas -u allcock
  2. sbank-list-allocation -f "id p avail" or > sbank-list-allocation -f id -f p -f avail For -u, -p and -r the use of wild card "*" is allowed, but only on names, not ids:
Examples:
  1. The following command will find allocations for users whose names start with "pers" and also users rojas and allcock. > sbank-list-allocation -u "pers* rojas allcock"
  2. The following command will find allocations for projects that contain "ratio" in the name. > sbank-list-allocation -p ratio
  3. The following command will find allocations for projects that end with "tion" in the name. > sbank-list-allocation -p *tion
  4. The following command will find allocations for projects that start with "ab" and end with "ng" in the name. > sbank-list-allocation -p ab*ng
For -f option: This option is the display field option.
To get the available fields enter -f? or -f "?". Default fields columns will be displayed if no field option is specified.
To replace the current fields to display, enter:
> sbank-list-allocations ... -f "FIELD[:WIDTH]...FIELD[:WIDTH]" or > sbank-list-allocations ... -f FIELD[:WIDTH] ... -f FIELD[:WIDTH]
If you wish to add fields to the default fields, enter one + symbol anywhere in the quoted string:
> sbank-list-allocations ... -f "+ FIELD[:WIDTH]...FIELD[:WIDTH]", only one + symbol is needed.
The fields will be displayed in table format and in the order entered in the command line. You can specify the field width, where WIDTH can be positive or negative value. Left alignment use -, right alignment use + or nothing.
For -w option:
FIELD:WIDTH, if the field is displayed it will change the width for the specified field.
NOTE: This will not add the field as in -f option, only change the width. To get available fields you can also use -w? or -w "?" as in -f option.
For -S, -E, --created, --queued, --last-updated, --history-date-range options:
These are the date filter options. All dates are treated as UTC.
You can use any reasonable date string that resembles a date Ambiguous dates will be parsed with the following parsing precedence: **YEAR then MONTH then DAY **
For example, 10-11-12 or 101112 will be the following date: Oct. 11, 2012 Not: Nov. 12, 2010 or Nov. 10, 2012
Or you can specify a single date as follows:
"[OPER]UTC_DATE" You can specify a date range as follows:
"[OPER1]UTC_DATE1...[OPER2]UTC_DATE2" Where OPER can be one of the following operators: "==", ">=", "<=", ">", "<" or "eq", "ge", "le", "gt", "lt"
Note: The following defaults for OPER, OPER1, OPER2 for the following options:
Options OPER OPER1 OPER2 ------------------------- ---- ----- ----- -E, < >= < -S, >= >= < --at >= >= < --created >= >= < --eligible >= >= < --last-updated >= >= < --queued >= >= <
You can also use the following key letters "n", "t", "d", "w", "y" as follows:
KEY SYNTAX DEFINITIONS ---------- ----------- n[ow] now, where "now" is current-date current-time UTC t[oday] today, where "today" is current-date 00:00:00 UTC [+/-]d specified "number" of +/- days from "today" in UTC [+/-]w specified "number" of +/- weeks from "today" in UTC [+/-]y specified "number" of +/- years from "today" in UTC
For -T option:
Transaction type option. The following are the valid transaction types and their explanation: CHARGE filter on job charges PULLBACK filter on allocation pullbacks DEPOSIT filter on allocation deposits REFUND filter on job refunds VOID filter on void transactions
INVOCATION
sbank sbank sbank sbank-detail sbank detail sbank d sbank-detail-allocations sbank detail allocations sbank d a sbank-detail-jobs sbank detail jobs sbank d j sbank-detail-projects sbank detail project sbank d p sbank-detail-transactions sbank detail transactions sbank d t sbank-detail-users sbank detail users sbank d u sbank-list sbank list sbank l sbank-list-allocations sbank list allocations sbank l a sbank-list-jobs sbank list jobs sbank l j sbank-list-projects sbank list projects sbank l p sbank-list-transactions sbank list transactions sbank l t sbank-list-users sbank list users sbank l u
ENVIRONMENT VARIABLES
Command line default options: Define the following environment variables as you would in the command line. Once the environment variable is defined, it will be used as the default options and arguments for the specific command. Command line options will take precedence.
sbank_DETAIL_ALLOCATIONS_ARGS
Default arguments and options for sbank-detail-allocations.
sbank_DETAIL_CATEGORIES_ARGS
Default arguments and options for sbank-detail-categories.
sbank_DETAIL_NAMES_ARGS
Default arguments and options for sbank-detail-names.
sbank_DETAIL_MESSAGES_ARGS
Default arguments and options for sbank-detail-messages.
sbank_DETAIL_JOBS_ARGS
Default arguments and options for sbank-detail-jobs.
sbank_DETAIL_PROJECTS_ARGS
Default arguments and options for sbank-detail-projects.
sbank_DETAIL_TRANSACTIONS_ARGS
Default arguments and options for sbank-detail-transactions.
sbank_DETAIL_USERS_ARGS
Default arguments and options for sbank-detail-users.
sbank_LIST_ALLOCATIONS_ARGS
Default arguments and options for sbank-list-allocations.
sbank_LIST_JOBS_ARGS
Default arguments and options for sbank-list-jobs.
sbank_LIST_PROJECTS_ARGS
Default arguments and options for sbank-list-projects.
sbank_LIST_TRANSACTIONS_ARGS
Default arguments and options for sbank-list-transactions.
sbank_LIST_USERS_ARGS
Default arguments and options for sbank-list-users.
EXAMPLES
Example 1: -f, --field
> sbank-list-transactions ... -f field1:-20 -f field2:20 -f field3 or > sbank-list-transactions ... -f "field1:-20 field2:20 field3"
Explanation: Fields will be displayed in order of appearance, where field1:-20 means 20 characters long, left align; where field2:20 means 20 characters long, right align; where field3 uses default sizes. Number fields default to right aligned. Text fields default to left aligned.
Example 2: -S, -E, --created, --queued, --last-updated, --history-start, --history-end
Single date-string examples:
  • sbank-list-allocations -S ">=Oct 11, 2014" start dates that are >= "2014-10-11 00:00:00"
  • sbank-list-allocations -S "<=2014-11-10" start dates that are <= "2014-11-10 00:00:00"
  • sbank-list-allocations -E "<20141110" end dates that are < "2014-11-10 00:00:00"
  • sbank-list-allocations -E "22:30:10" end dates that are < " 22:30:10"
  • sbank-list-allocations -S ">today" start dates that are > " 00:00:00"
  • sbank-list-allocations -E t end dates that are < " 00:00:00"
  • sbank-list-allocations -S gtnow start dates that are > " "
  • sbank-list-allocations -E len end dates that are <= " "
  • sbank-list-allocations -S "1d" start dates that are >= "today +1 day"
  • sbank-list-allocations -E "-2w" end dates that are < "today -2 weeks"
  • sbank-list-allocations -S ">=1y" start dates that are >= "today +1 year"
  • sbank-list-allocations -S ">2012" start dates that are > "2012-- 00:00:00"
Range date-string examples:
  • sbank-list-allocations -S "2013-01-01...2014-01-01" "2013-01-01" <= DATES < "2014-01-01"
  • sbank-list-allocations -S "-1y...t" "today -1 year" <= DATES < "today"
  • sbank-list-allocations -E "2013...t"" "2013--" <= DATES < "today"
  • sbank-list-allocations -E ">2013...<=t"" "2013--" < DATES <= "today"
Example 3: Command invocation examples
  • sbank-list-projects list projects full command invocation
  • sbank list projects list projects meta command invocation
  • sbank s p list projects partial meta command invocation
  • sbank p list projects where "list" is the default
  • sbank list allocations is the default
  • sbank a list allocations "list" is the default
  • sbank s a list allocations partial meta command invocation
Example 4: -h, --help
  • sbank -h will give you help summary on all of sbank
  • sbank list --help will give you help on all the "list" commands
  • sbank list allocations -h will give you help on the "list allocations" command
  • sbank-list-allocations -h will give you help on the "list allocations" command
  • sbank l a --help will give you help on the "list allocations" command
