Skip to content
Manpage for sbank-list-users
sbank-list-users [options]
Generate user list report.
Notes:
  1. Use -I to include inactive allocations
    1. for information for all resources, use "-r all"
OPTIONS
--version
show program's version number and exit
-h, --help
show this help message and exit
-a ALLOCATION_ID, --allocation-id=ALLOCATION_ID
filter on allocation id
-f FIELD_INFO, --field-to-display=FIELD_INFO
FIELD_INFO is [:], for available fields enter -f? or -f "?", to add fields enter -f "+ [:] ..."
-n NUM_FIELDS_TO_DISPLAY, --num-fields-to-display=NUM_FIELDS_TO_DISPLAY
set number of fields to display
-p PROJECT, --project=PROJECT
filter on name or id, DO NOT MIX, enter 'all' to get all, wild cards '*' is allowed, but only on names
-r RESOURCE, --resource=RESOURCE
-u USER, --user=USER
-w "FIELD_INFO", --field-width
"FIELD_INFO" FIELD_INFO is :, for available fields enter -w? or -w "?"
-E END, --end=END
[OPER1][...[OPER2]], where the operators OPER1 and OPER2 can be one of the following: - ge, gt, le, lt, eq or >=, >, <=, <, ==.
Operator Defaults:
  • OPER1 is 'lt' for single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry.
Date Parsing Precedence:
  • YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov. 1, 2012
-H, --human-readable
abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions) ...
-I, --get-inactive
also get inactive allocations
-S START, --start=START
Operator Defaults:
--debug=DEBUG_LEVEL
SILENT, MUCH_LESS, LESS, MORE, VERBOSE, DEBUG, DEBUG1, DEBUG2
--all-charges
only show list info that have charges regardless of project/user relationship
--no-commas
remove commas from comma-separated thousands
--no-header
do not display the header
--no-rows
do not display the row data
--no-sys-msg
do not display system message
--no-totals
do not display the totals
